Can Someone Help Me Decode This?
66ChargerHI-PO
5:55 PM
Connecti-Chit
Can someone help me decode this? It's from our 66 Charger we started "restifying." Just wanted to know "what we got" here. So I can "document" it. Any help would be appreciated. Thanks in advance.
What I know-
X: Charger
P: Premium.
29: 2 door sports coupe/ fastback
WW1: White paint
G is for 383, not sure if they distinguish between 2 or 4 v on that. It’s the numbers under the A and B on the fender tag that will determine if it’s a 2 or 4 v. Under the c is the trans. The fifth digit in the vin is usually the engine code for Mopars as far as I know. On my 66 cuda formula S was a D which was for 273 cu. BP29D62500159 was the vin. The 6 after D was for the 66 year.
Fender tag
abcdefgh......
625
= 383 4 barrel automatic
I think its either, meaning the "G", but 383 for sure.
Mostly right. If it were 2 bbl it would be 61 engine code, 5 is automatic
383-2 not available in 66 Charger. Would be a 361-2.
66 VINs are a little different. G code only tells you 383 not which 383. That’s determined by application.. so in a 66 B body, G tells you 383-4.
62 on the tag = 383-4.
