Carb help needed
bee71
8:33 AM
St. Augustine, FL
My 71 Bee has a 383 4-speed. The numbers on the Carter 4-barrel are H8 4616 S. I can't find this carb listed anywhere. Is it the right one or did the previous owner switch it out? What was the stock Carter for a 71 383 4-speed with A/C and manual brakes?
Your carb-69 383 A/T. OE carb? All I can find are 2 bbls. for that year with that combo.
1971 383's used a Holley R4667 or R6191 without an airgrabber and a R4734 or R6193 with an airgrabber.
I'm beginning to think it is a replacement. The broadcast sheet under carb says 48 for whatever carb it is supposed to be. However, I know that they did put Carter carbs on certain 383's and I think mine is supposed to as the Holley ones were for the 335 horse and 440 engines.
beginning to think?..lol
48 is part# 3512 848
Holley model 4160 list number R4667A
383 4bbl 4-spd w/o N96 on B & E-bodies
either that or a 6191a is what you want....
here is a carb list for 70 and 71
you can see mopar was carb crazy back then
with all the different choices there are.....
1970
383 manual - E & B-body - with ECS (N95)
orange HP engine 335hp
---------- Holley R4217-A ---------- part number 3418 537 on b'cast 37
383 manual - E & B-body - w/o ECS
orange HP engine 335hp engine on b'cast 084 with A/C & 087 w/o A/C
---------- Holley R4367-A ---------- part number 3418 536 on b'cast 36
383 manual - E & B-body - w/o ECS & with "fresh air" (N96).
---------- Holley R4736-1A ---------- part number 3512 964 on b'cast 64
383 manual - E & B-body - with ECS (N95) & with "fresh air" (N96).
---------- Holley R4738-1A ---------- part number 3512 974 on b'cast 74
383 automatic - E, C & B-body - w/o A/C & w/o ECS
blue engine 330hp
---------- Carter 4736S ---------- part number 3418 538 on b'cast 38
383 automatic - E, C & B-body - with A/C (H51) & w/o ECS
blue engine 330hp
---------- Carter 4732S ---------- part number 3418 540 on b'cast 40
383 automatic - E, C & B-body - with ECS (N95)
blue engine 330hp
---------- Carter 4734S ---------- part number 3418 541 on b'cast 41
383 automatic - E & B-body - w/o A/C & w/o ECS
orange HP engine 335hp engine on b'cast 088
---------- Holley R4368-A ---------- part number 3418 542 on b'cast 42
383 automatic - E & B-body - w/o A/C & with "fresh air" (N96).
---------- Holley R4737-1A ---------- part number 3512 965 on b'cast 65
383 automatic - E & B-body - with ECS (N95)
---------- Holley R4218-A ---------- part number 3418 543 on b'cast 43
383 automatic - E & B-body - with A/C (H51) & w/o ECS
orange HP engine 335hp engine on b'cast 089
---------- Holley R4369-A ---------- part number 3418 562 on b'cast 62
383 automatic - E & B-body - with ECS (N95) & with "fresh air" (N96).
---------- Holley R4739-1A ---------- part number 3512 975 on b'cast 75
1971
orange HP engine
---------- Holley R4667A ---------- part number 3512 848 on b'cast 48
383 manual - E & B-body - with "fresh air" (N96).
orange HP engine
---------- Holley R4734A ---------- part number 3512 849 on b'cast 49
* some sources show the following manual trans carbs w/same part numbers
* 383 manual - E & B-body
* orange HP engine
* ---------- Holley R6191A ---------- part number 3512 848 on b'cast 48
* 383 manual - E & B-body - with "fresh air" (N96).
* orange HP engine
* ---------- Holley R6193A ---------- part number 3512 849 on b'cast 49
383 automatic - C-body
blue engine
---------- Carter 6125S ---------- part number 3512 844 on b'cast 44
orange HP engine
---------- Holley R4668A ---------- part number 3512 830 on b'cast 30
383 automatic - E & B-body - with "fresh air" (N96).
orange HP engine
---------- Holley R4735A ---------- part number 3512 842 on b'cast 42
fwiw also
be prepared to pay alot when you find one
since there were so many different ones used back then
the holleys were notorious leakers
not many are left to be found today.
i have alot of loot into a 6193...
i know of a few 6191's for sale
and none of them are cheap.
i'm talking more then 300 just for a core!
