Carb
67 joe dirt
10:34 PM
Oak Hill, WV
I installed a new holley carburetor on a 383 the brake booster port is in the back but I don't have power brakes the car runs but when I block off the port it stalls the engine and quits do I need to run it to something else
Maybe too rich? Try setting the idle mixture more lean.
You should be able to just cap it off.
Ok ill try that also the it idles about 800rpm with idle screw backed all the way out if that suggests anything else I need to do
Make sure the secondaries are completely closed.
Ok ill check everything out i was able to drive it straight out of the box but I'm sure it needs some tuning just didn't know what to do
