Caster bushings
Bighouse
11:10 AM
New York
Looking into getting the Moog offset bushings. I have a 69 Charger and I was only able to get 1.1 degrees positive and the car is following grooves in the road.
Would I be installing the bushings in the rear a arm pivot with the the bushing positioned to pull the upper ball joint to the rear and toward the center of the car?
I’m also going to replace the strut rod bushings and inspect for damage hoping that will pull the lower ball joint forward.
Yes you can do front, rear or both. Depends what you have for camber currently.
Ie, if you just did rear, you'll pull the camber in. And the front is probably maxed out.
