Change from 383 to 440??
MoparMikey
3:07 AM
SoCal
orig 1965 Coronet 383 4 spd, will my existing bellhousing/flywheel bolt up to the 440 without issue? Same question if i did a stroker 440 or stroker 383, crank flanges same pattern etc?? Thanks.
Yup on the stock stuff...on the stroker, the flywheel depends on what stroke you go to. Some stroker cranks have an 8 bolt flange like the Hemi.
Everything bolts right up. Just bake sure that the new engine has a crank drilled for a pilot bearing/bushing. Like cranky says, if you have a hemi eight bolt crank, you'll need an eight bolt flywheel.
