69SportSatellite
The 1967 440 going into my '69 Sport Satellite came from an Imperial, so it has the standard or non-HP exhaust manifolds. We're switching over to the HP manifolds / factory dual exhaust and my mechanic says it looks like we'll need to swap the VC's to account for different plug wire routing. I have read that they made different VC's for HP motors.
I've seen the article in Mopar Enthusiast from Tony's Parts, which details the differences by year. I see the '67 has a heater hose bracket support while the later years apparently do not. Is it necessary to use year specific VC's to each motor?
Also, I believe I will need to go with stock replacements due to the different angle of the bolt/stud between factory and aftermarket heads. I see that Year One reproduces the Direct Connection VC's but wonder if they have the correct bolt/stud angle for stock heads? I would also note they don't have any plug wire tabs...?
Any information would be appreciated - or, if there is an existing thread on this topic, feel free to point me in that direction.
Thanks!
Thanks!
