Charger 73-74 and 75-78 rear suspension differences
shone190
1:14 PM
Serbia - Europe
Hi guys,
do you know are there some differences between 73-74 and 75-78 Charger rear suspension (leaf springs, shocks, sway bar...)?
Thanks.
Yes, you can convert the later cars back to the "normal" shock plate. The late cars had a weird iso shock plate that is notorious for rotting out.
Shocks also change due to eyelet/eyelet vs eyelet/rod.
I have a 78 model 2 door I converted back to the normal shock plates and shocks. Bought normal B body springs also. I did a spring relo, so not sure if the leaf spring length is 100% the same
73-74 still have the iso shock plates (rubber Mount)
In other words it's all the same
The 72 and early have the no rubber witch you can chand it over to also (witch is best performance wise)
The rubber is a good thing just get some polly rubbers and you will be fine (tons less work)
