Charger build discussion
I'm running 1.12bars, Borgesson, QA1 adjustable UCA's, QA1 adjustable push rods, QA1 steering rods with my own tweak to get rid of bump steer. It runs like a new car on the road, love it. I think the key components are the adjustable UCA's and my tweak to get rid of bumpsteer. I set my suspension to 5deg caster, -1deg camber. The caster improvement makes your steeering a lot less nervous.
Lowering the outer steering rod pivot point with roughly 1" from oem will get rid of bumpsteer and makes the steering feel great through cornering and possible pot holes. That's my Best advice.
I follow you on the 1.12's, Borgeson, UCA's but not the Qa1 adjustable push rods. I have the steering rods from Qa1... I have not had one on the rack to check elevated vs ride height toe changes. I suppose going to a Heim style rod end open up multiple way to lower the outer tie Rod End. Clarify?
