charger rear seat removal
sdyer233
10:01 AM
massachusetts
hey there, so im looking for the build sheet for my 74 charger, can anybody inform me on how to remove the rear seat so i can check the underside of it? I tried just pulling and i looked along the side and bottom for bolts but couldn't locate any..
There shouldn't be any bolts holding the rear seat in place, instead there are hooks weelded onto the floor that hold the wire frame structure of the seat in place. I believe that if you push backwards (towards the trunk) on the sides of the front face on the bottom section of the seat, you can free the seat fromt these hooks and then lift it up and out. As for the seat back, there are also hooks, and if you play around with it a little you can get them unhooked as well. If you don't have a rear seat trunk divider you should be able to see the hooks to figure out which direction to push the seat, otherwise you'll have to just try pushing on the seat in different directions until it becomes free. Sorry I couldn't be more descriptive, it's been a while since I took my seat out, but hopefully this gets you pointed in the right direction.
Push in on the seat at the bottom you can use your knees [sometimes they are tough] then you can lift the seat bottom out. The seat back will be hooked at the top but two bolts hold it in at the bottom [after you remove the seat bottom you can see the bolts.
