Roughbird72
- 1:32 PM
- Oct 18, 2014
- North Central Indiana
and half of next year's budget is spent. lol
That's the plan, i never trust that ootb machining is in tolerance. My best friend has a flow bench, he'll be all over these like a hobo on a ham sandwich.congrats, a friend of mine bought some , they looked very nice, make sure you check them over good, valve job, guides etc. before running as with anything ootb.
It may be a little while yet, still accumulating parts for this build.View attachment 366783 can't wait to see them installed.
Good to hear that! My 71 440 in my 70 V code Roadrunner runs strong with the (recently identified) 292/509 purple stripe cam, especially since I added new Comp Cams lifters springs locks and retainers. I have tuned the carbs on the aluminum 6 bbl intake and the FBO ignition system seems to be working well. It appears to be a stock short block with 452 heads-stock other than the Comp Cams hardware. So I would expect a significant improvement in performance by just bolting on the Trick Flow 240s...are those the 240s? What motor are they going on?Nice!
A friend recently put these on his 440 street car and it totally transformed the car!
I haven't even got everything for the 463 build & I picked this up today.![]()
Something else to trip over.lol
std. bore out of a 77 Newport w/67K
I've seen them further down the hole.lolGood block and looks like a forged crank but the pistons are probably .160 in the hole! LOL!
Yeah like 100+cfm better...Yes, they are the 240s.
I have been accumulating parts to build a 463" RB(3.9 stroke w/7.1" rod)
The difference between stock 452s & Trick Flows should be very noticeable. IIRC stock 452s only flow around 225-230cfm.
Not at all!I've seen them further down the hole.lol
The block is all i wanted. I don't think i got hurt for $300 for the shortblock.
