SOLD cleaning out the garage
TO THE TOP WITH CHANGES, get your Obama refund ready
-fresh rebuilt with brewer parts18 spline hemi 4 speed case date april of 1972 with B/E tail housing $1500
-fresh rebuilt with brewer parts 23 spline 4 speed case date c1965 B/E tail housing $1000
-mopar b/rb purple cam new p4529318 .533 lift $125
-D440 HP2 build date 10-11 & cast date 8-26-67 bare block with caps tanked & magged standard bore $700
-426 street wedge bare block with caps & heads no casting dates build date 3-21 tanked & magged standard bore $700
-classic air complete a/c conversion including rebuilt heater box for 68-70 mopar b-body everything is new or like new. This set up is the only complete & easy to install unit on the market $1200
-68- b body dana never cut complete but taken apart with 3.54 gears $1200
NO HAPPY ENDINGS
can bring to carlisle if prepaid
NO HAPPY ENDINGS
-mopar b/rb purple cam new p4529318 .533 lift no lifters $100
- e383hp build date 8-26-2 cast 4-28-68 std bore from dart vin LS23h9b tanked & magged $1000
Interested in the 18 spline if you still have it. Is the gearbox Aluminum cast? Can you possibly send some photos? ........... Thanks, Calvin 69 Satellite.
Please do not post phone numbers as per site rules.
oh no you ditant
****UPDATED LIST***
oh no you ditant
cleaning out the garage & the extras need to go!!!
-new mopar perf hemi cross ram never used or mounted $600
-very rare edelbrock str 14-6 intake uncut or modified $700
-a12 air cleaner assembly with filter,base plate is a repop fiberglass piece $300
-E383 hp from a 68/69 cuda very rare A body engine with caps correct heads ,crank ,intake, water pump & the hard to find drivers side motor mount & early A body K frame.
Cast 9-26-67 / build date 8-21 tanked & magged standard bore $2k for everything
-A body 440 drivers side motor mount $150
-B body adjustable steel strut rods $100
-B body aluminum strut rods $150
-sure grip with 3.23 gears $250
- sure grip no gears still has ring gear installed $150 SPF
- sure grip no gears $ sold
-489 case 3.55 gears sure grip $ sold
-edelbrock performer #1407 750cfm square flange, manual choke like new $175
-mopar B1 heads,valve covers, 2 intakes & b engine spacers all new or like new just been sitting a while $2500
-edelbrock torqer 383 intake in great vshape $75
-68-69 b body dana never cut complete but taken apart with 4:10 gears $1200
still have the Mopar cam 533 mopar b/rb purple cam new p4529318 .533 lift $125?
thanks..Jeff
what air cleaners do u have? what all comes with the a12? there 4 bbl air cleaners aint they? im looking for a dual snorkle or a air grabber style for a 4 bbl
DUH!!! A12's are only 3x2.
