Gentlemen,
Spark plugs are simple but complex items. What the factory installed was basically a compromise for general use....a combination of "city" (50% driving) & "highway" (50%) driving. A nominal heat range for a given engine, say a 383 cubic inch Roadrunner 335hp, in stock configuration would be a Champion J-11Y or P-34P Mopar. For those guys that "hate" Champion plugs, the brand of their choice is OK, but the important consideration is engine. Factors such as fuel mixture, octane rating, fuel distribution, spark advance (both initial and total), RPM, all influence spark plug type and heat range.
I can only speak of my application. My RS23V '70 GTX's engine 440 (0.030" bore) has 11.0:1 TRW pistons, fitted at 0.004", Crane cam (equal to the Mopar 292 degree, .509 lift), Prestolite dual point distributor, plus rejetted carbs, 4.10 Dana, built for "street" use. The plugs I use are Cnampion UJ-11G (non projected insulator tip and non resistor) with the G suffix for gold paladium alloy electrode OR Champion HO-8A pure platinium electrodes. The HO-8A plugs were developed by Champion for a niche application for Homelite racing 2 cycle go cart engines running a fuel mix of methanol-nitromethane and castor oil at 10,000 RPMs. Why such special plugs????? Answer: because they work for me. They are not made any longer...I buy them when and where I can find them....just about all the folks selling them have no idea what they are for.....I have a large supply of both types stashed away. These plugs last for years due to the materials used in the electrodes. Would they work in your application???? That must be detetmined by you.....I only know what works for me. One must "read the plugs" - cylinder by cylinder to determine mixture and distribution patterns. Combustion chamber temperature is the biggest influence on spark plug heat range selection...error on the cold side....fouled plugs are easier to fix than a melted piston....the old addage of "caviet emptor", paraphrased....let the owner decide....
Cheers,
RJ Renton
