Column shift likage
CTMopar
7:14 AM
CT
Feedback: +2 / =0 / -0
I am looking for a complete automatic column shift linkage for a 69 B-Body big block (I don't know if SB or S6 are the same).
I have that complete linkage set Small block 904 and big block 727 have different pieces
PM sent
I got the one from Moparparts. I have the linkage from a 68 Newport and it looks like the only difference from that to the b body set is the bracket that bolts to the frame. The c body bracket wont clear the lip at the top of the frame.
C-Body crosshafts are wider and have different lever placement 904 B-Body shafts have different lever spacing and configuration than 727
I put them next to each other and you are correct the C-Body shaft is longer.
