WTB Complete Cruise control setup for 66 Satelite
Mark Armand
6:12 AM
Mebane, NC
Feedback: 2 / 0 / 0
Looking for a complete cruise control setup with the control on the turn indicator. Let me know what you might have. Thanks Mark
This is what I have from a later model b-body:
I also have new plugs for the wiring harness:
Was cruise even avail option on 66 B bodies
I have used cruise control setups out 1970's Cordoba's / Charger's in my cars with success.
This looks like what I used in post # 4. You have to come up with a brake light switch that activates the brake lights and deactivates the cruise control at the same time. I could not find any switch for Chrysler products, but found one on Rockauto for 1980 GMC that will do the job, with modification of wire harness. You will also file a clearance notch on steering column collar for the wires coming out of the cruise control / turn signal stalk. Failure to do this will eventually cause the wires to rub bare and cause a short circuit. Ask me how I know this!
OOps. Post # 2 shows the required Chrysler brake light switch with the setup. You will also need the small adapter that attaches to carb linkage that cruise control cable hooks to. There should also be a bracket that bolts to one of the master cylinder studs that the cable routes through.
I have the lost motion link that goes on the carb linkage and the cable bracket for a big block . BOTH nos
This looks like it should be in the tech section?? I know there's stuff here that I didn't know about even though I've had a few old Mopars with cruise control.....
