Compression Check
50 Coupe
6:01 AM
Indianapolis
Is it possible to check compression by hand turning the crank using a breaker bar or does it need to be spun up faster via a starter?
(My motor is on a stand and I don't have a starter yet but when I tried turning by hand I couldn't get any readings. However, the timing chain is really stretched, maybe that could be the problem. I will put the new one this weekend.)
I would imagine the engine needs to turn faster than possible using a breaker bar. What you see on the gauge is a culmination of several rotations.
If you are just checking condition of rings, valves and head gaskets a leak down tester would work if you have the tools. It wouldn't tell you anything about comp ratio.
