rustytoolss
When I bought my car ( 62 fury wagon) it came with a " Performance online" power brake booster and master cylinder that was already mounted on the car ( dual 8" booster & 1.125" mopar style master cylinder ) I fought with it untill I gave up and installed a DR Diff 15/16" full manual master cylinder. The car just would not stop safely, hard pedal, but the booster seemed to be working ???
At some point I would like to reinstall the PB system. For those of you that have converted from drum to a conversion power brake system ( disc/drum). What size master cylinder bore are you using ? I'm thinking that 1" master cylinder might have helped me out.
I have the smaller rotors disc's up front, with the big bore slider calipers, 10" rear drum brakes with new wheel cylinders, all new hoses, and adjustable brake valve to the rear brakes.
I'm thinking that the 1.00" bore should make the system work ???...any thoughts
