Coolant Drain Plug - 426 Hemi
6769Mopars
9:45 PM
Apollo Beach, FL
I do not see one on my 67 Hemi GTX. Does anyone know if there is a coolant drain plug on the hemi and where it is located?
There should be one in the bottom of the radiator as well.
Drain plugs on the block should be the same as all the other big blocks. If they've never been out, good luck with that. Are you trying to winterize it? I usually just pull the hoses when the engine is hot and what little is left will evaporate out. Besides, there's not enough left to hurt the block even if you did live in a very cold climate but if you are trying to get them out for other reasons, try it when the engine is hot. It's usually easier that way.
Thanks, guys. I bought the car last June and want to put fresh coolant in it. Based on the above, I'll do as Cranky suggests. I'm not interested in doing battle with drain plugs.
