I plan on upgrading the stock 318 radiator in my 65 Coronet with a stock looking and fitting copper/brass constructed high flow design. I would like to use a Mopar Performance viscous fan package and an electric fan set up on the front of the radiator. I have a 727 automatic tranny and a Hemi going into the car and my questions are as follows:
1 - If I go with a 4 core high flow design it will be 5/8" wider then stock (not sure if this will even fit with a MP fan set up) but it will not have transmission cooling capability. So what I was wondering is can I just use an add an aftermarket transmission cooler or should I stick with a 3 core which has transmission cooling fittings on the radiator (and add an aftermarket cooler)?
2 - What do think of having an MP Vicious fan package and a electric fan in front of the radiator....will this provide enough cooling?
Note: I plan on having a shroud and I really like the stock belt driven fan look.
Thanks for any advice you guys can send my way, it really is appreciated.
