Cordoba pin caliper brakes
68chargerpilot
7:53 AM
Spartanburg SC
I saw a video by the ram man about front brake upgrades. In the video he talked about the pin type caliper of the Cordoba. Well as luck would have it i ran into a cordoba in my local junk yard this week. Front brakes are mostly unmolested. The driver side still had the wheel on it. The passenger wss off exposing the brakes. It had the pin caliper and bracket. The two pins and retainer however were missing ( or possible in the leaves).
Here's my question? Is the bracket the part to get or should I get the caliper too. Do they make the missing pins if I can't locate them?
He sold the pin brackets and calipers but it was an upcharge. If i have them right in front of me...... should i? Gonna go on my 68 charger.
the caliper brackets and mounting bolts for them is what you need
the rest you can buy from rock auto.
some people will also use the spindles
they do change the geometry of the suspension
which is a debate if its good or bad
many do report it will work fine.
after brake bits,not much else that i know of
there are some big block parts like
valve covers and such
bucket seats might be worth a couple of bucks also
that stuff might not be correct but you can still use if you are in need.
