WTB Coronet Wagon parts
willem
6:57 AM
The Netherlands
Feedback: +0 / =0 / -0
Hi,
Not sure if im posting this in the correct thread, but i'm looking for some specific parts for the tailgate of a 1972 Dodge Coronet Wagon.
The plastic blocks are mounted to the glass, intended do make the window slide through the rails i suppose?
The other parts are the rubber moldings alongside the glass. I dont know the correct english term for these, but they wipe the window clean of rainwater when you slide the window down. I hope this makes sence, i've added some pictures of the parts i pulled out of the car (or what's left of them)
regards. Willem
20190419_110109.jpg 20190419_110113.jpg 20190419_110121.jpg 20190419_110127.jpg 20190424_083652.jpg 20190424_083658.jpg
In the USA, the second item you mentioned is usually called "cat whiskers". My guess is that you need to contact a supplier (like Top Cat) and see if they can sell you longer pieces that they use to cut out ones for car side windows.
Thanks, i'll try contacting one Googling Cat Whiskers & Top Cat gives some different results though :D
We (in the netherlands) call those things "Window lickers"
Ok, this is the reply i got:
Top Cat does not deal direct with the public, they would require you to send
your original piece to see if it could be matched up with any reproduction
weatherstrip they would have on hand. There is no guarantee there would be
anything available that would work.
Do you know of another company, besides Top Cat?
Just check on Ebay for someone selling Top Cat
I should be able to take care of the window felts and possibly the seal across the wagon's back window. I need to check our samples of used felts to see if I have a set available to use as a template. Due to the limited demand for items like these, it is not like I have them already made up and ready for shipping. I do not have the nylon guides that goes along the sides of the wagon's rear door glass.
