correct undercarriage paint
citadel
10:00 AM
Dallas, TX
guys,
I wanted to check and see if the below was correct regarding the colors used on a 69 roadrunner:
Lower control arms- black (semi-gloss)
upper control arms- black (semi-gloss)
torsion bars- black (semi-gloss)
strut rods- black (semi-gloss)
K member- black (semi-gloss)
pit-man, idler- natural
center link and adjuster bars- black (semi-gloss)
Not quite. UCA and LCA are bare steel. Also the strut rods I believe. T bars are always painted, dipped really, and will have drips. All the other suspension stuff is natural like the control arms, but colors vary depending on materials and heat treating. K member is semi gloss black and I have found that SEM 2 part hot rod black is a pretty good match.
i have seen a few k-members that were a darkish semigloss grey; i have one under my unrestored Savoy; i don't know if that was the case with roadrunners. But in most cases it is indeed black.
you can find a lot of info here:
http://www.mmcdetroit.com/
