Couple 69 front door questions
pearljam724
4:53 PM
U.S.
I have a 69 Coronet Convertible. Does the charger share the same exact door panels as the Coronet R/T and Super Bee ? 2nd question- after removing arm rests and window crank what is needed to remove the panels ? Do you just pull on the panels to pull out plastic rivets in the door frame ?
Last question, lol ! Does anyone reproduce the driver door window channel that holds the fuzzy felt up against the window ? That piece of trim is missing, causing window to be lose I believe. Window moves about 3/8 if inch side to side. Thank for any help
Yes, just carefully prise the panel off from the outer edge, maybe using a platic tire lever or put some tape over the end of a screwdriver so you don't scratch anything. Don't be too rough or the clips may stay in the door and pull out of the panel back.
