'67Satellite
Lucky
Well,
i was wrong...
of course, it's not the first time and probably not the last lol
Make sure the crank rings like a bell when tapped with a ball peen hammer. If it doesn't ring its cracked.
Thanks Meeps, this week I am headed to the machinist to go over sonic test of the 400. Over the phone he said that 2 cylinders were 'thin' if going with a high horsepower build. lI'll drop off the 440 block to be checked then.
A good running street engine is definitely the goal, with a high percentage of highway miles.
NOTHING wrong with a std inch 440 !!
We recently did a couple of el cheapo 440 pump gas builds with Flat Tappet Cams, Stock LY Rods etc.
We Dyno everything before it leaves, so I can dig up the sheets if you want ?
* One came in at 490hp and 550 ft/lbs all in by 5,000 rpm(leave it in "D" Engine)
