cylinder head install
runner74
6:39 PM
MA
Ok
Installing 400 big block cylinder heads today. From what I understand only oil lightly on all bolts then 40 foot lbs then 70. Do any of these bolts go into water jacket and require sealer? I don't think so but want to be absolutely sure. I know the exhaust studs do.
Oil on threads, oil on head bolt shoulder area, torque to final in three steps. I usually go 25-50-70 following the proper sequence. Bolts should not go to water, but it is easy to check with a light and screwdriver; bottoms out-blind, goes thru-to water.
