mpro69rr
Hey Guys,
I worked on my 69 RR 383 4 speed this weekend. The car was running great before the work. I replaced the water pump and alternator. Got everything connected back up and went to start it and got a click the dakota digital dash blinked and then no power. I have the MAD wiring for info. I put the old alt back on and nothing. I checked the battery and got 12v, I tried connecting the two studs on the starter relay with a screw driver and nothing. Checked fusable links and fuses all seem fine. I checked power at the starter relay and the meter flashed all kinds of numbers so I assume there is no power there? Why I changed the alt was because I was receiving high voltage, sometimes 15v so I thought I would put the old alt back on to see what kind of volts I would get, I thought maybe maybe the power master alt was bad. I don't understand why I wouldn't get 12v at the starter relay? The battery gets 12v? Could it be a bad battery, it was working great before I replaced the alt?
