Dana 60 Carriers
Thunder65
3:56 AM
Ontario, Canada
So I finally spoke with Cass at Dr. Diff. He has confirmed that there is no such thing as a Series 2 or a 2 Series carrier and that the 4.10's should fit.
The only issue may be that the gears are from Richmond, if so then they will not fit. Guess I will have to call the shop and see if in fact they are Richmond gears. Cass says it is not necessary to change it all out and not to waste my money, just purchase the correct 4.10 gear set. I really appreciate his honesty, however now I am totally confused, some say there is a series 2 and some say there is no such thing. By the way it is a Dana60 not a Dana61. AARRRGGGHHH!
You don’t want a 61, it’s a bastard!
