Dana 60 question
nbbcrh
7:06 PM
KY
Gentlemen, I'm refreshing a Dana 60, Seals, inner and outer, axle bearings, pinion seal, brakes etc.
The question is there a gasket behind backing plate(against axle tube) and a gasket on the front side of brake backing plate and the axle retaining plate.
I know the service manual shows one, but it doesn't show in relation to backing plate, Thanks in advance for your help. Ben
There should be a metal gasket between the housing and backing plate and a foam gasket between the backing plate and the axle retainer.
Thank you for your help, the order is in for them
