Dana Rearend Question
69_Charger
2:31 AM
Illinois
I found a reasonable priced Dana rearend from a 73 that I was interested in installing on my '69 Charger. If my information is correct my 8 3/4 shaft is too long for the 73 rearend and I would have to shorten it to get it to fix. Am I asking for trouble by shortening my shaft or is this something many people have done with little to no issues. Last thing I want to do is shorten the shaft, regret it and then be in the market for a new shaft.
Yes, the driveshaft for the dana is shorter than for the 8 3/4. You can cut down the shaft if you want. When I put the dana in my car, I had a new driveshaft made and put the original 8 3/4 and driveshaft in the corner of the garage.
Do a test fit first before you spend your money. Sometimes, the 8 3/4 shaft is a bit short for the 8 3/4 in the first place. Seen it before.....
And,if it is actually a 73,it's to long for a bolt in for your 69.
If it's a 73 then its from a truck cuz 72 was the last year for a Dana in a car. Also as said before if its a 71/2 then it will be almost 3" wider than your 69 and the perches are over 3" wider.
When I was looking for a Dana 60,used Danas were almost the cost of a new Moser or Strange,I went with a Moser through a Canadian dealer ,spec my gear ratio , suregrip,axles etc just the way I wanted and it,s brand new!
