Innoi
First off I am a new owner of a 1969 Dodge Coronet. I have wanted one for 15 plus years and finally became a proud owner of one a couple of months ago. Great car, tons of fun. I bought a running drivable car but it does need a couple of things here and there in my mind just to keep it road worthy.
Anyways one of the areas that keeps nagging on me to fix is the dash, gauges. I have the standard 120 square style with no clock or factory tach. The previous owner put a bolt on tach on the dash that works, and also the typical 3 gauge under dash setup with oil/alternator/temp gauges that all work.
I want to get the original dash back working and maybe add in the stock tach to the cluster. My first plan of attack was to inspect the wires and see what was what. I'm new at this stuff but my wire harness from under the dash looked pretty good, it actually looked untouched. I checked the fuel tank and followed the blue wire all the way to under the dash, no issues or breaks. So it all looked pretty good to me so far. I checked the tach and saw the typical splice fitting on the coil wire but it looked good. I couldn't find or just was not looking in the right area for the alternator wires but I'm assuming since the new gauge works the wires are good. I don't have a bunch of extra wires going everywhere under the hood, which is good.
I did a little research and saw that some of the dash problems could be related to a bad voltage limiter. So I ordered one online, seemed like a reasonable place to start for my gauge issue. Put the new one in, fit perfectly and rechecked the gauges. No change. Every thing still worked but just not my original gauges. I checked the fuse box and all my fuses looked good. One thing I forgot to mention is that the cluster does light up when I turn on the headlights, so that is good.
Just wondering what my next step should be? My main concern is to get the fuel gauge working because it sucks driving somewhere and always filling up the tank because I think I'm going to run out of gas.
