Dash lights
Gregg DeGeorge
3:26 AM
Naugatuck Ct 06770
Hello all ,still working on my 68 Roadrunner ,drove it through the summer dash lights never worked,did replace fuel and temp gauge with classic units gas gauge just quit last week ,but back to dash lights ,signal ,high beam ;dash lights never worked ,thought I would try new printed circuit board and go from there ,any thoughts ?Electrical is my weakest skill but drove home from cruise tonight dark cluster ,any thoughts would be helpful thanks
Have you tried bypassing the headlamp switch and jumping power to the dash light wire?
Throwing parts at it may never fix anything, but will get expensive and time consuming.
Suggest you look over the printed circuit board first, before running out, and buying a new one. Look for any burned spots, corrosion, or loose connector pins. Ohm test each separate circuit, for good readings. If it's bad, sure, replace it. If it's good, start looking elsewhere, for the problem.
Ohm test the wiring that goes TO the circuit board, and use a test light, to see if your actually getting power to it. If not, look at your fuses.
