Dash question
72satteldog
10:33 PM
minnesota
Difference between a rally dash and non rally. I assume one has the tach and one does not? Are there other differences?
As I understand, the Rallye dash is the version with round gauges, whereas the Standard dash has what I would call square gauges. Rallye may be with or without the tachometer.
The Rallye gauge pack has the 4 round gauges, and can contain a Tach or Clock or neither. It is wired from behind with a harness.
The standard cluster has the square gauges and traditional style "sweep" Speedometer. It is wired from the rear by a plug which connects to the circuit board pins on the back. It had a fuel gauge and I think the Oil/ Temp/ and Clock were an option
