Moparbuster
My carb acting crazy car starts dies like outta gas backfires front sprayers just dribble but back sprays right if I pump pedal
Well, the squirters don't really do anything as far as keeping the car running...do you mean it dies only when you throttle it? What's been changed or worked on, or was it working fine and this just started happening out of nowhere? Jerry makes a good point, check the level in the bowl and make sure the float moves free.... but if it starts and then immediately dies it could also be a problem with the ignition (ballast resistor or coil). If you feel strongly that it is the carb, get a rebuild kit and give it a re-fresh.My carb acting crazy car starts dies like outta gas backfires front sprayers just dribble but back sprays right if I pump pedal
