Difference in Brake Linkage
Vandie12
New Member
7:56 AM
Michigan
What is the difference in the 70 and before and the after 70 B body brake linkage. This is the linkage between the booster and pedal.
1966 - 1970 B-bodies uses the same linkage between the power brake booster and brake pedal. 1971 - 1974 B and E bodies use the same type of linkage that look the same but not sure if exactly the same.
There are differences in the push rod, hub, lever and some of the hardware. The size and ratio are different on the hub/lever and the push rod. A 71-72 B & E are different than a 73-74 B & E the 70 E Body is on its own and as mentioned 70 and back B-Body is the same
