Dipstick and TTI's
joelrpo687
9:22 AM
Connecticut
Can anyone tell me what they used for an engine oil dipstick with TTI's on a 440.Does the dipstick go between the header and the head or outboard of the header.Got the header dipstick from Mancini and it fits for s---.Thanks
Outside the header tube. You may have to put a slight outward bend in it. I'm using a stock Mopar tube/stick.
Get the Lokar dip stick then your done with it or Milidon
Got the milodon for the trans- did not fit(got one fron CRT- went right in) Got an engine one from Mancini-no good-I'll give lokar a call-there stuff usually works-thanks
i just used the stock tube and stick with 2" tti's on my 65 coronet. tube fit to the outside.
Mine is also outside the header. The bracket of the dipstick tube bolts to the eng mount bracket where it bolts to the block. Ron
Big difference when it comes to Hemi, the head takes another 2.5 inches span across the engine compartment. You can put the Wedge inside the Hemi with space left over.
Thanks for the nice picture.I see you're old school on the wiring.The Ron Francis harness eliminates all the stuff on the firewall.Facing the engine the starter relay is first,then the voltage reg.( I think) then the little guy above the ballast resistor is what? Could that be the horn relay.I guess I could reassemble my harness and see where the green horn wire goes.Guess I forgot after 2 yrs.
Yes the wire harness's are basically all stock other then I redid some of them and made a harness for the electronic ign. And yes that is the horn relay as I wanted my horn to work with all the crazy drivers out there. Ron
Outside the headers...
