Muswagon
- 7:13 PM
- Jan 16, 2011
- Winnipeg, Manitoba, Canada
Hey there. I am having brake issues on my 68 Roadrunner. First, the backround story;
- Car was factory power drum. Old stuff was worse than junk, bought SSBC front disc conv kit
- Had NO brakes at all, new booster, still no, turns out master cyl from bunk in box from SSBC
- No brakes now due to no vacuum, 78 440, guy that built has stupid cam, for now went with vacuum pump....'some' brakes. Pump pulls 19 inches ish
- The last hurdle now is that I am 99.9% sure even though I ordered the booster for power disc, they gave me power drum...in fact make that 100% sure
My question is, with good vacuum, new master cyl, new front kit, properly bench bled and properly wheel bled, will having a single diaphragm booster for drum cause poor assist with front discs? I believe the calipers are the Mustang Kelsey Hays style, as replacement pads are 67 Mustang I think the manual said.
When I stand on it, and the boost is over, the brakes will lock, and there is alot of fluid pressue when we crack the caliper bleeder to check.
Will a dual diaphragm booster be my saviour? And from the looks of it, this is the one I need; http://napaonline.com/Catalog/CatalogItemDetail.aspx?R=NBB5473603_0332947700
