Disc brake conversion questions
gstead65
New Member
8:54 AM
indiana
hello, looking for some assistance in wanting to change drum brakes to disc brakes on 69 super bee, all stock. any help would be appreciated. How big of job is it and can what kits would you suggest. thanks
I used Dr Diff kits. Start a email dialog with Dr Diff and he will guide you through the process.
There are a lot of different ways to go. Some here will tell you that the conversion kits that use your existing spindles are the best. (they are easier) Some will say to get new spindles made for disks. I'm in the second camp. Either way read the link in coronet68mx's post.
Another for the Dr. Diff kit.
I went with a wilwood disc brake kit. And was amazed at how easy it was to install, I used the original drum spindles and manual drum brake master cylinder.
I get all my disc brake conversion stuff from Dr. Diff. Great guy to deal with.
Thank you for sharing and saving a new guy a bunch of headaches by trying to figure it out.
You could go with newer model disc brake parts! Alot cheaper!!!
I'm sure someone can go into what's needed more . I know I sell upper lower spindle out alot at swap meets for this reason I have a few setups here I usually get $350 a pair shipping might be rough though you might find a setup near you.
