Distributor issue - points dwell
AR67GTX
10:12 AM
Arkansas
Hopefully someone with a little distributor repair background can weigh in on this.
A little background - I put a rebuilt NAPA distributor in my GTX several years ago because of worn bushings in the non-original one in it. Typical of most rebuilt stuff I think it was assembled from bins of parts with no attempt to maintain original specs and it had about 30 degrees mechanical advance so it ran poorly. I finally got around to welding up the advance slots and filing them out and ended up with 20 degrees (crankshaft) centrifugal timing. From trial and error I discovered I had to be real careful to file the slots for a snug fit of the advance plate pins in order to maintain steady timing. Everything ended up running fine - big improvement with 16 degrees initial advance.
Today I was checking points and timing and points checked out at 28 degrees dwell which was where I last set them. I plugged the vacuum tube and checked initial timing and it was OK at 16 degrees - but I glanced back at the dwell meter and it was now showing 30 degrees dwell (??). I plugged the vacuum line back up to the distributor and the dwell dropped back to 28 degrees again. I repeated this several time with the same result. Otherwise the dwell reads steady and doesn't vary with reving the engine. So anyone have an idea what is going on to cause this? Doesn't seem to be hurting anything as it's steady under either condition.
I would say typical.. In the dual points distributors, the advance plate rotates on a center ball bearing.
Not so on the single points. On these, the pivot is a pin, which makes the plate move in an "arc" across the shaft center. There is no way this can ever be accurate.
I used to HATE single point distributors. "Back in my day" (my 70 V code came with dual points) on some of my engines I scored a tach drive hemi dual point unit, at one time had a GM breakerless (the old Vette before HEI) modified to fit a Mopar, and not long after the Mopar breakerless came out in 71 or 72 I ran THAT
You used to be able to buy bushing kits at the dealer "for cheap." I used to buy them 2 or 3 at a time "just to have." Wish to hell I had about 10 of them now.
That's normal for mopars and fords. As the diaphragm pulls on the point plate, the radius changes in reverence to the shaft. This also changes the point gap,so the dwell is changed also. There isn't any easy way to fix. And yes, all of them do the same from the factory. Pat
OK - thanks for the replies. Never noticed this happening before but it was just by chance I did today. One less thing to worry about.
Yes - before I went for the NAPA rebuilt unit I checked at the local Dodge dealer for a bushing kit. When I mentioned it was for a 67 GTX they looked at me like I was from another planet.
