DIY kit for flex hose for defrost, AC and heater vents?
munger77
6:36 PM
Atlanta, GA
is there a universal DIY kit of flex hose for under the dash ducts to defrost vents,
ac/heat vents. not sure if they are circular or rectangular flanges on the vents and if it matters. I'm not near my car to look.
under my dash the vents are circular ,ac vents
they do sell these
what year car?
The original material was a paper type of material which can be still purchased, although much more difficult to find. Most of the restoration vendors sells the plastic style ducting as pictured above with the molded ends. If your only needing the hose sections, you can purchase it through NAPA, but most of them sells it rolls of something like 25 feet.
Thanks 69 b fan; I will measure the diameter when I drive my car for the first time in a few months. I think the ends are 2.5 inch in diameter, with the defroster ends being 2 3/16 in diameter.
Munger77, your inbox is full as I tried to send you a message.
Ok, I'll clean it out or fork up the $$ to become gold again,
I may have your email address, let me check. Thanks
I found your email, I will drop you an email.
