Door hinge rebuild
dodge68charger
12:40 AM
Washington
Im looking for a kit or company to rebuild my door hinges on my 68 charger. Can anyone recommend a kit or reputable place to get mine done. Thanks
Just want everything to be tight n no sags. Kinda like my women lol. Thanks i'll check it out
If theres any other companys also that would be appreciated. I havent had good luck on ebay
I did my own, one was really bad so I welded the holes shut and re-drilled them and put new pins in it. The other that wasn't so bad I just went to the local auto parts store and bought a pin that was slightly larger and drilled it to match the pins. All of the pins I used were in stock items (maybe for different makes) but got the job done and you can't tell the difference.
http://www.megapartsusa.com/proddetail.asp?prod=112-DHK101
Where ever you get it, I would recommend changing the springs as well. Grooves wear into them, thus the door doesn't like to stay in position (swings open or shut freely/when not wanted).
Good luck
Resto Rick has new oversized pins and springs in a kit he also sells the reamer
to cut the holes to match the new pins. Check him out on the web
Thanks guys, appreciate the help. Gonna head to the shop and take the old ones off, get them cleaned up and take it fron there. Thanks again. This site comes through everytime!:)
Has anyone got a pic of their lower, driver side door hinge? I'm rebuilding mine and I've seen pics with the spring in different ways. On some pics the curved end is on the top but I've seen a few with the curved end on the bottom.
You could try moparleo over on FEBO. Does a nice job and sometimes he has hinges in stock.
That's because there is no lower left or right side specific door hinge, they're identical. One side is flipped vs. the other, thus a curved spring up top on one side, flat sided on the other.
