Door Panel Removal
Chargered
6:47 PM
Peosta, IA
I need to pull my door panels off of my 70 Charger to do some work on the window crank mechanism. I've never pulled them off before and just wondering if anyone has any helpful hints? I'm not sure if they are fastened on somehow with screws or do they just pop off? Thanks for the help.
the panels are attached with molding clips tractor supply sells a set of tools for removing trim pieces 4 tools 1 is for the door panels, 1 is for the windshield moldings 1 for removing door handles and one more @ 4 15- 20$ remove the door handles ,armrest etc. and the clips are around the outside edge of the trim panel @ 6 to 8" apart. use the tool to pry up under the panel at the clips and your good
They simply pop off. Start at a corner and do not use a screwdriver! You can do it with your fingers. Arm rest and window crank will need to be removed separately as well as the upper door panel.
