Door panel trim
delfinomuro
Houston,Tx
Ok I have a question, is the door panel chrome trim on top different from the one on the bottom? Or the same?
For a 66-67 plymouth satellite 2-door hard top
The top trim is a retainer that screws to the door. 66's are different than 67's, and I believe that somewhere in the 66 model year it was changed to the 67 version. The lower ss trim piece clips to the panel itself, and is a flat decor piece. Not the same.
I should have some top pieces if you are missing them.
Thank you, but I figured out they're different in length. Mines are the ones that slip into the door panel. My rear ones are screwed though.
