Hey everyone,
Thanks for all the input. GTX, I think you were on to something with one of your previous posts. So I've been doing testing all weekend and finally just decided to install a lighter secondary vacuum pod spring and bump the timing like 1 degree. That totally made a difference. I guess the higher flow of the DP4B liked the secondaries coming in earlier. I had it dialed in before with the OEM manifold but it seems it needed a bit more with the new configuration. I went from the brown spring, past the plain, to the purple and there was a very noticeable difference in highway acceleration from 65-70 on up. Also from about 30, dropping into 1st and punching it, manually shifting up through the gears, it pulled hard but very smooth.
I'll keep playing with it and maybe go back down to 67 primaries from 68s to see what that's like.
Thanks again,
Mikey
