Drain hole clearing
JG1966
8:11 PM
Pittsburgh
How do I clean/access a drain hole passage? The front right drain hole along the rocker panel on my 72 Roadrunner is clogged/closed. I was checking the other five drain holes and I was able to easily run a coat hanger up at least 12-18 inches on all of them. I pulled the quarter panel extension drain plugs and they were both clean behind. But on the passenger side drain hole about six inches rear of the front door jam, the hanger wouldn't budge. I tried a small screwdriver and hammered it up and made it about 2 inches. It's not leaves or debris or dirt anything like that. It's almost like the passage is completely closed. Any suggestions? Thanks
