Moparguy1
I have an engine that I bought that had been rebuilt and never started. The assembly lube they used has dried so I am taking it apart to get all the lube cleaned up. What can I use to remove all the lube without hurting the bearing, rods or crank? Also do you think it will be a problem to reuse the bearings after they are cleaned up and relubed?
