Driver side front wheel hub for 1967 Coronet R/T
Polsky
6:12 PM
Kaukauna, WI
Feedback: +0 / =0 / -0
Found out this week that I have a cracked wheel hub on the car.:angryfire: I am having trouble finding one on Ebay and other local sources. Let me know if you have one that fits. The car has 11x3 drums in the front if that makes a difference. Thanks in advance.
do you need the hub where wheel bearings are or the drum ? i have hubs from my 66 belvedere that i think would fit. i switched to disk brakes. mike
Yes Mike, I do do need the hub where the bearings sit but am not sure what hubs would work. Looks like the lugs are opposite for each side. Can any one else chime in and confirm that they will fit?
According to the Hollander Interchange Manual, All 66 thru 69 B Body spindles are the same including R/T & Road Runner. The only difference is if they are disk or drum spindles.
Thanks a bunch!:headbang:
66nut, PM me when you get time with price and other info. Thanks again.
The thing different is right and left threads! the hubs are the same!
