Driveshaft removal help
ct71rr
Chad
6:20 AM
Massachusetts
I removed the bolts on the rear universal joint at my 8 3/4. Do I just slide the driveshaft toward the tranny to remove it? How the heck do I get this thing out?? :thinker:
Thanks in advance,
Chad
screwdriver or prybar between U-joint body & rear flange will loosen it enough to slide forward...don't forget to put a pan under the trans output shaft to catch the small amount of fluid that will run out
Wow, quick response! Thank you, I really appreciate it :icon_thumright: !!!!!!
