4mulas
- 10:59 PM
- Mar 16, 2017
- Just North of Great Falls
If you were to run a 2” dropped spindle do you need a certain minimum size wheel in order to provide clearance between the wheel and the lower ball joint?
If I’m thinking this through properly, do you achieve the drop by raising the position of the Center of the spindle where the wheel bolts on in order to achieve the drop, thus making the bottom of the wheel that much closer to the lower ball joint? And would also increase the distance between the wheel and the upper ball joint?
