E brake pedal removal
68 440+6 R/T
9:45 AM
USA
how do you remove the pin and retaining clip from the E brake cable.
there’s one position around half way down
You will see an access hole to allow removal of the clip. You will probably need to loosen the tension on the cable to do it.
There's an access hole on the pedal housing. You'll need to eyeball it to align it.....
