I'd put a Street Demon 3 bbl 625 (now from Holley)
smaller primaries & large secondary
or the Holley Street Avenger vs 670 4150, style carb
bolt it (either of them) on
right out of the box, no need to tune they are 'near perfect' as is
several I know have done it on a mild combo like yours
(they all had older versions of the Webber/Edelbrocks AVS or AFB knock offs)
before I'd even do the Webber/faux Carter AVS,
unless you find an org. one & rebuild it , for a restoration to look like stock
otherwise get a good carb
I've never had good luck with them Webbers/Edelbrocks, & I'm not a huge fan
& I know how to tune them too, just not to my likings
if the car sitts for periods of time too, will be hard starting
the fuel evaporates out of the bowls in the Webber/Edelbrock, Carter faux carbs
way faster for some reason
to each their own, that's my opinion, honest suggestion
take it or leave it
Engine Masters did a great episode on it too
Cheap Carb Shootout
the Demon will fit a dual plane intake too, notice the underside
they did a test on Engine masters too, great right out of the box
they are a bit harder to tune, have to take the carb off
screws are underneath, but for your combo I'd bet you don't even need to touch it
other than setting the choke for your climate
