Edelbrock Carb Idle issues
twecomm
7:23 AM
Pittsburgh PA
Got a Edelbrock 1406 carb on my 383. Started having idle issues, rough and erratic RPM's. Saw an Edelbrock video showing if experiencing idle problems, one thing to try is to remove both idle mixture screws and blow compressed air into the screw holes to clear any dirt may be blocking the small passages for idle fuel flow. Then replace idle screws turning full in to gently bottom out and then back off both by 1- 1 1/2 turns to get you into the ball park for idle mixture. Worked perfectly, solved the problem. Of course, you probably want to go through the procedure to fine tune idle mixture with vacuum gauge as covered in the carb instructions after.
Yep. If the car sits for any long length of time, those ports will varnish over.
I like to have ethanol free gas in there whenever possible. Sometimes if I'm driving a bunch within a few days I'll run some "high test ethanol".
I had this happen before, like 2 years ago. This time around when issue re-surfaced, I finally remembered that video. Took a while, memory aint what it used to be...
